Old 03-25-2016, 03:41 PM
Bernica's Avatar
Bernica Bernica is offline
Senior CC Premier Member
Originally Posted by Tonus72 View Post
Hi.
I am looking at the same thing.
When I did the shed slab a few years ago I put in a trench footing across the spot where I 'thought' I wanted the lift.
Now I think it would be better about 1 metre closer to the roller door. Doh...
There is a trench footer the whole way around the perimeter of the slab and the slab is min 100mm thick.
Bearing in mind it still complies, and the trench footing is nearby, I am hoping it will be ok to move it to suit my layout...
I got a price a few years ago for a Tech Lift 6253 delivered to Tassie - I just need to get an updated price.
Tony
I am thinking that if your current trench footing for this lift is 1 metre away, then you do the same thing I recommended BUT, since it's down there and you will be digging anyways, tie into it with some rebar dowels epoxied into the trench footing if you can. If you can't, just forget the old footing and do new one(s).
Again, my 2c
