Old 03-26-2016, 02:10 AM
stephen low's Avatar
stephen low stephen low is offline
Default New adjustable top arms
So as part of the smarten up I've fitted adjustable top arms into the front. I also fitted up 15mm spacers into the suspension set up to drop the front and loose some of the 4WD look.
The 15mm spacers achieved almost a 50mm drop and the car looks much better, though in the pic it doesn't look much, the car is visibly more level.
Fitting up the new top arms I had to open up the skirts somewhat but this all worked well with a die grinder.
So moved from S2 Jag top arms...
To mustang adjustable arms as....
With a fair bit of Marty's intervention to build new top mount arms and manufacture tapers to suit the Mustang ball joints.
So the car is bound for Rob Tucker in Hastings next Friday and with luck the car will be nicely aligned and good to go for the Fest.
Here's hoping for some nice weather.
slowy
