Old 03-29-2016, 07:55 AM
750hp's Avatar
750hp 750hp is offline
I'm not if "can be fixed by using tubes" meant that he actually fitted tubes, but here's an old comment about the Billboards:
Originally Posted by Power Surge View Post
I've had the billboards on my car for over 8k miles.
Only "bad" points I've experianced... They flat spot when they've sat. That goes away in a few miles. They leak air through the porous sidewalls. That can be fixed by using tubes. They bite very well, so if you hit a batch of "uneven" road (where the grind it down to lay fresh stuff and it's all lines) or going over a grated bridge, they will grab the ruts and pattern in the road and you will fight to keep the car straight.
Other than that, I love them. I will be putting another set on when these are done (they have tons of life left at 8k BTW).
Craig
