Old 03-30-2016, 11:18 AM
Tim7139's Avatar
Tim7139 Tim7139 is offline
Cobra Make, Engine: Superformance #2660, FE-406
Originally Posted by Brdslayr View Post
I'll take any info I can get and appreciate it. My email is brdslayr@charter.net Hopefully I can find a part number and just buy the shoulder part of the harness.
When you get the ass end up and wheels off, you can see the hole in the frame and locate the slot in the bulkhead behind the carpet. Slit that with an exacto knife.
You want a harness set with a single metal bracket, which you bolt up through the cross member. i think I used a grade 10 5/16" bolt and large washers with a lock nut. Takes about 10 minutes a side.
Did mine the same time I installed the shock mount upgrade, last summer.
The older I get, the faster I was.
