Old 04-01-2016, 11:04 AM
Joe's Garage Joe's Garage is offline
Originally Posted by jacobsed View Post
big block all the way
You NEVER hear anyone say "Man...I wish I had put a small block in"
Seeing how some of you would like to rehash this SB vs. BB debate, enjoy -
small block vs. big block in a cobra
Originally Posted by SPF2245 View Post
My .02, I got the chance to drive a big block...it's everything everyone said it was. Great sound, power fall off in the upper RPMs and too much low end power for the tires to stand a chance. I then drove a small block stroker and found the upper power band was more usable while the lower tq off idle allowed for more chance to put the power to the ground. End result, I've got a stroker small block. Is it the end all...no way, I could use another 50-75HP so 4th gear would be as exciting as the first three.
-Dan
Originally Posted by madmaxx View Post
Unless you are buying an original you are getting a replica which takes advantage of many of the automotive advances through the years. Why not take advantage on engine technology and get a stroked 351 to 4??. Now you have big block performance plus the advantages of a lighter engine.
I have been in and heard both. Unless they are parked next to each other it is hard to dicern the big block. I also did not like the low ground clearance as a result of the big block bell housing. Just my thoughts.
Originally Posted by Slick61 View Post
I've got a 427 Windsor stroker. Has the Dart aluminum block, so is very stout AND light weight. I think I get the best of both worlds... big block power (612 hp/615 tq) with small block weight (car weighs 2240 lbs). Am surprised no one has mentioned a few other advantages of the small block... has more room to "breathe" in the engine compartment & you have better accessability during maintenance/service.
danc30,
I do not have anything right now although I am slated for a Roush 427. I did intentionally pass up on two SPF's with 460's that were substantially less cost. If I wanted a trunk engine I would buy a truck. If I wanted an engine that overheated on a regular basis I would get a BB, if I wanted to plow into every turn I would get a BB, if I wanted to scrape every speed bump I would get a BB.
I'll check back later to see if the tomatoes have started flying.
