Old 04-01-2016, 05:42 PM
Dan Case's Avatar
Dan Case Dan Case is offline
Original Shelby Owner
Lens(es):
As A-Snake suggests there is more than one version of lens. The basic design was used for more than a decade. Over time the structure of the lamp socket changed and so did the lens(es). There are at least four different lenses, three red and one amber that I know of and there could be more. Only one was used in production by AC Cars (Based on my own survey of unrestored substantially unmolested uncrashed Cobras between a CSX20xx chassis and some early 427 Cobras while lots of such cars were still available to study.) during the Cobra and early 427 Cobra production time frame. There have also been replacement parts not manufactured by Lucas available since the late 1980s.
The most desirable for top tier restorations is the same version AC Cars used but none are worthless. Value depends on how badly somebody wants them at the time.
The exact raised text molded into the lens panels and the fine details (Lucas original or later replacement) are clues to what version is being examined.
Valve Covers:
Which ones, what chassis series? Cobras with XHP-260, HP260, and HP289 engines used many different valve covers street and race. The only ones easy to identify as production Cobra pieces are the three known cast aluminum versions used for engines with road draft tubes or PCV ventilation sourced from the rear of intake manifolds. The tougher to decode are the two cast aluminum versions made before late 1964 (when sourcing of parts for 1965 MUSTANG GT350 production ramped up). The versions used on Cobras had different Ford engineering numbers and costs than the subsequent GT350 parts, but very early GT350s finished at Venice got left over Cobra production covers. During Cobra production there was a wooden master to produce late Cobra valve covers. During 1965-66 GT350 production there were many different wooden masters; I don’t know how many but at one time I had parts from five different masters on the work bench at one time.
Dan Case
