04-10-2016, 08:07 AM
AR
The problem with air shocks is that your primary control is by height/air pressure. More air pressure means more height. If your car actually sits low and needs to come up in the rear some - an air shock might work. But if you like the stance or just need a very slight increase or need to stiffen the spring/shock action a little - you probably will not find air shocks to be the solution.
