Old 04-10-2016, 10:11 AM
joyridin''s Avatar
joyridin' joyridin' is offline
Originally Posted by wkooiman View Post
Forging consists of dies that force the steel together, much like you mash snow together to make a stronger snowball. A 90-degree crankshaft would consist of a complicated set of dies, just to get the crank out of the dies after forging. It is simpler to have 2 dies that forge in 1 plane, and then after the crank is removed, the crank is twisted into the correct orientation while the steel is still malleable.
There are non-twist forged cranks, but they are surely more expensive, and the cranks from the 60's were surely all twist forged.
You can google this, and find sites that explain it better.
Ok...I have never seen a twist forging. I visit a couple places that manufacture cranks and none of them use this method. Thanks!
