Old 04-11-2016, 08:51 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Is is a high pitched squeal/squeak?
Sounds like the contact face of the throwout bearing on the pressure plate fingers.
If this is a normal push clutch, the trans should come off like normal, the only thing that could stop it would be the input shaft is reluctant to come out of the spigot bearing in the rear of the crankshaft.
Gary
