Old 04-13-2016, 05:34 AM
joyridin''s Avatar
joyridin' joyridin' is offline
.014" is too much. You are probably going to feel a pulsating in your pedal when you hit the brakes. You stated you checked the hat. Did you check the rotor after it was bolted on the hat? The outside edge of the rotor is probably going to be around .02" when you take the larger diameter into consideration.
