Thread: New Halibrands!
Old 04-14-2016, 09:02 PM
Springbok Springbok is offline
Cobra Make, Engine: 1965 Cobra made by Pacific Roadsters. 351 Windsor Crate Motor, 5 Speed Tremec Transmission
Looks Great! You will be thoroughly enjoyed with the improvement. Now you get to explain to others what a knock-off is!
Oops, just noticed. You forgot the safety wire! Drill a small hole in one wing of each spinner and run some safety wire around a spoke (you can cover the wire with a piece of rubber tubing so that it does not mar the wheel) and through the hole in the spinner. Do not tighten it fully, leave a little slack so that you will know if the spinner is starting to loosen. If you notice that the wire is tight later, then you know that you need to tighten the spinner again.
Its not in the photo but I have it on there now. I had the clip on there that it came with, wanted to drive it first, retighten and then add the safety wire.
