Old 04-19-2016, 03:16 PM
SVO 050 SVO 050 is offline
Cobra Make, Engine: AC Adelaide, SVO 5l, Tremek 5Speed, jag front and rear
Default Tail shaft loop
Gregg, there are some aftermarket 2 piece loops available but I used a piece of 125mm schedule 40 pressure pipe, cut it in half and welded 5mm flat bar tabs to pick up the cross member and used high tensile socket head cap screws to install it.
Overkill in the strength department and will pass any engineer or inspectors requirements.
SVO
