Old 04-19-2016, 05:11 PM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Thanks for the tip SVO. I've got the expanded mesh on the shelf so will probably use it. It's pretty open and free flowing.
The car will be primarily a street car but I plan on doing regular track days in it.
A 2 piece hoop would be easier for servicing the drive shaft. This one piece hoop is still easy to get out from underneath it's just you need to unbolt a few extras including the drive shaft flange to remove it. A bit of a pain as I have to loosen the hand brake cables and unbolt the cooler pump to get it out but access is good from underneath.
I liked the idea of a small diameter hoop that fits closely around the drive shaft. If something does break it won't deflect far as it rattles around in there. This was about as close as I could make it while maintaining clearance and still being easy to remove.
Mike Murphy
Melbourne Australia
