Thread: Setting Timing
Old 04-21-2016, 05:41 PM
Bernica's Avatar
Bernica Bernica is offline
Senior CC Premier Member
Phil - I think he means a last check for any sign of vacuum leaks around the intake gasket and carb gasket since either one will elevate idle speed somewhat.
Thanks Dan. That's exactly what I meant. Check all your vacuum plugs on carb and make sure one isn't missing. I know it's frowned upon, but I have used starter fluid to spray around carb and intake at idle to help find any potential leaks. There are other safer methods...
