Old 04-26-2016, 07:17 AM
Tim7139's Avatar
Tim7139 Tim7139 is offline
Cobra Make, Engine: Superformance #2660, FE-406
Originally Posted by Dwight View Post
Last spring I bought a brake bleeder vacuum kit. Now changing the brake fluid in a car is a one man job that takes about 30 minutes.
I have done six cars and a F250 so far.
I buy two large cans of fluid. You will need an air compressor to use this kit.
I bought one similar to this unit
Mityvac MV6830 Vacuum Brake Bleeder
I have one and they are not bad, although mine is the original hand pump unit. I believe, however, the pressure systems that connect to the master work better in a lot of systems. I use the pressure system from Motive and it eliminates any air being left in a caliper. The rub for these cars is connecting the cap with it's hose to the master. It's a tough bend through the access panel and has to be done from the engine compartment .
The older I get, the faster I was.
