Old 04-26-2016, 01:19 PM
dsmith74 dsmith74 is offline
Default Weber/Stacks linkage expertise needed
Hey All,
Does anyone know of any shops/people in New England (preferably close to the Boston area) that are really good with tweaking/troubleshooting/fine-tuning linkages on Weber and/or stack injection? My dad has a stack injection on his 63 replica that we cannot get to run right, something is way off with the linkage. For the past few years we've been messing with it trying to get it straightened out...but haven't had any luck. The drivers side TB's are the one's directly connected to the bellcrank...passenger side is driven by a cross-link to the drivers side. I can get drivers side and passenger side synced up (using a syncrometer) at idle without any issue. But, once you start giving it throttle...the drivers side opens up way, way faster than the passenger side butterflies. There isn't any slop or play in the linkage, it's all tight...but just off idle the drivers side TB's start pulling about 3 times the amount of air the passenger side TB's are. So what you end up with is one side (passenger side) running pig rich...and it bogs, coughs, spits, crackles etc... It's almost as if where the linkage connects to the passenger side TB's is further down the throttle arm from the fulcrum than on the drivers side...so the drivers open faster, passenger side opens slower. But that's not the case, I've measured...and they are the same.
Pics are at the below link so you can see what I'm talking about re: the linkage:
P5260414.jpg Photo by pballent | Photobucket
Thank you very much, -Dave
