  #133 (permalink)
Old 04-27-2016, 11:46 PM
LMH's Avatar
LMH LMH is offline
Originally Posted by ALF View Post
Hi Larry
I assume you're referring to the Lucas wiper switch PRS 7.
Could you please provide a picture or more details about the bezel you did mention in your post.
Thanks
ALF
The PRS7 is a series of switches made by Lucas. The two speed wiper version of the switch as found in the Cobra was intended to work with the DR3 two speed wiper motor. In the SPF/late CSX leaf spring cars, I don't think it would work as they don't use a DR3 motor. Probably the way to do it would be to machine a bezel nut that fit the switch that came with the car, yet be shaped like the original. Then have it plated.
The bezel nut has a bevel that faces outward. Looks like this:
(this is before I had mine rechromed)
Alba gu brąth
