Old 05-04-2016, 05:03 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Actually looking forward to June 24th although my wife is more than a little jealous and I believe she will be making me a list of things I need to do every day before she leaves for work.
A side note on the coupe: I got all my gauges they were not working to function correctly last night. I found out that my tach was not working because I had forgotten to ground my VSS wire (it's yellow in my wiring harness). My fuel gauge works best when I put in more than a gallon in a 22 gallon tank. My cooling fan came on as expected when my water temp gauge reached 180 degrees.
A new problem is my clutch is not engaging so I must re-bleed the thing which is a lot of fun but I saved all my red neck bleeding devises and if it works I will take pictures. At any rate the coupe is beginning to come together.
On another issue if you drop the end of a wire tie onto your headers and forget to remove it before you start the engine ....it will smoke and melt and ruin whatever part of those high dollar titanium header wrap they melt on. Just an observation!
"Let's roll"
"Be part of Something Good
