Old 05-04-2016, 05:41 PM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Back to the original point & post: my .02:
1. I don't really buy the 'original looks' argument. Most 5 speeds now have
an 'original look' shift handle available and the only way to tell would be
the top of the knob (shift pattern) or a look under the car; and it is far
easier to spot a replica than climbing underneath!
2. The 5 speeds (TKO500=95 lbs) tend to be lighter (barely) than a
toploader (98) [Trans ONLY: loaded the tko's are 105lbs, TL 109]
3. The 5 speed can keep the engine in a lower rev ban, saving stress and
expense both during engine build and general economy (gas).
4. Performance of the 5 speed will match a toploader AND give decent
cruising. I own a '66 GT350 and the little 289 really hums with 3.89 gears
on the highway! Storing the 4 speed and installing a T5 WC made the car
MUCH more driveable and enjoyable.
5. A close ratio TL ratios are: 2.32/1.69/1.29/1 and the tko500/600 are:
(500 ) 3.27 1.97 1.34 1.00 0.68
(600) 2.87 1.89 1.28 1.00 0.82
(600) 2.87 1.89 1.28 1.00 0.64
6. Final drive ratio is the key! : Buying a TKO600 and installing a 5.36 rear is
nonsensical. IMHO; follow the lead of Shelby and use a .64/.68 OD; so
3.54 FDR (mainly street) or 3.73/4.11 (competition).
7. RPM @ 70, using 295/50R15 (26.61" tall):
3.56 FDR: TL: 3129 rpm; TKO (.64) 2015 rpm; (.68) 2139
3.73 FDR: TL: 3297 rpm; TKO (.64) 2112 rpm; (.68) 2245
8. Note that the 3.73/.68 will give (IMO) the best overall performance--great
acceleration AND nearly 1k less rpm than the 3.56/TL combo @ 70!!
9. Final consideration is the engine build itself. Did you build a 8k screamer or
a 6000 rpm street engine? Ideally,the trans you install wants to keep the
engine in its' powerband as much as possible--not over the cam limit and
not lugging. I suggest looking at your cam specs and playing with a
calculator like this: Tire Size, RPM, Speed, and Differential Ratio Calculator
/?ratio=2.54 to figure it all out.
10. Good luck and happy driving!
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
