05-05-2016, 06:23 PM
Senior CC Premier Member
CA
Originally Posted by patrickt
The black one limits you to 18 degrees, so if you want to shoot for 35 degrees all in, your idle timing will be 17 degrees. If you find you want less idle timing, like me, then you're going to have to change your bushing so the total comes out to the sum that you want. The bushing is easily changed, just Google a vid for it on YouTube. I use the silver bushing, that limits the advance to 25 degrees, and I have 10 degrees at idle, so my all in timing is 35 degrees.
Wow, 10 degrees to 25 all in Patrick? Sounds low, but I am sure I'm missing something. I have always been at 18/36 or thereabouts...
