Old 05-08-2016, 02:38 AM
landmass's Avatar
landmass landmass is offline
Cobra Make, Engine: Hurricane Motorsports, 363 cu.in. 613 HP
Thanks Talos for the suggestion. I think you have a driver's side pivot. I have the passenger side pivot which requires a longer throw from the slave. I've pretty much decided to make the switch, as I have simply been unable to locate a slave that will push the distance I want. I'm just tired of messing with it. I thought the McLeod TO would solve my slave problems, but it did not. I'm no spring chicken and working on the car is becoming more difficult. Mentally, I'm done with the clutch set up and looking for advice on what automatic transmission will work good with a high revving small block ford.
