Old 05-08-2016, 02:16 PM
Phx Mike's Avatar
Phx Mike Phx Mike is offline
Cobra Make, Engine: Ex owner of a polished Kirkham 427 S/C. Now Cobra-less and driving a mid-engine German hot rod.
Originally Posted by vettestr View Post
If you are willing to chase down the issue yourself page 2 of this document has a step by step, check (under voltage tests). Bet you a buck it turns out to be a loose connection and another buck it is on the negative or ground cable side.
http://www.cb4x4.com/PDFs/Electrical...%20testing.pdf
After checking connections you can (full field) alt. for a quick test to prove alt. does work or not. look here.... https://reconit.wordpress.com/2013/0...n-the-vehicle/
Thanks Jeff. I pulled the alternator out - all the connections were fine and it was not shorting against the cylinder head. It had it "tested" at the auto parts store and it "passed" although I don't have data on current vs speed/load. I replaced the regulator (connections there were good also). Checked battery connections and they were good. I have also bypassed a relay that sits between the ignition switch and regulator. Still get a slowly declining voltage the longer I drive. So - either not enough alternator output to keep up (voltage goes from 13 down to 11.5 when I have the fan on and then down from there at about 0.5 volts every 10 mins) or a grounding problem somewhere.
My schedule doesn't let me work on it full time so next stop is a shop somewhere.
Thx for all the help and will advise when it gets sorted out.
