Old 05-10-2016, 06:33 AM
Ron61's Avatar
Ron61 Ron61 is offline
To check if the Alternator is working, start the car and use a volt meter to measure across your battery terminals. You should read around 14/16 volts if the alternator is putting out the correct voltage. With the car shut off you should read 12/13 volts if the batteries are good.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
