Thread: Setting Timing
Old 05-10-2016, 04:23 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Had anybody worked on the engine in between when it left the engine builder and when you started tweaking the timing... and the other stuff?
That's a good point as well.
Did a nut get dropped down the carburetor by accident?
Did the spark plug look normal on removal?
If valve to piston clearance becomes an instant negative, something has to give.
