Old 05-10-2016, 05:34 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
There has been some leaps and bounds in crankcase breather systems.
This valve is certainly one of them.
As they say, the last PCV valve you will buy.
Coupled with a Moroso or Stef's air/oil separator would be a good system.
The more time the engine can run with a slight to significant negative pressure, (less than atmospheric) in the crankcase, the less acid buildup in the oil, the oil lasts longer, the less chance for oil leaks etc.
