Old 05-12-2002, 01:20 AM
Snake Snake is offline
Post DV
Thanks for the Ford part number. I got the weather stripping on the side rails and on the front end. Bolted the two bolts towards the cowl...and bolted them down...pulled the body down to a little more then 1/4 inch...is that about right? Guess what!! The bolt holes in the cowl bar lined up for the doors! Do you try and get, an 1/8 of an inch or, 1/4 of an inch all the way around the doors. Should I mount the bear claws and door posts...then adjust to fit. Still have some trimming to do on the doors...in the front closest to the cowl bar. What would be the best line of attack know DV? After reading one of your other post...you said that you put the windsheild in before you bolted the door area....wish I would have read that first....no big deal...inlarged the windsheild post slots in the body...and got the windsheild in ok.
Thanks DV What's next.
Snake.
