Old 05-14-2016, 09:09 PM
landmass's Avatar
landmass landmass is offline
Cobra Make, Engine: Hurricane Motorsports, 363 cu.in. 613 HP
Default Wilwood Brake Peddle - Proper Adjustment
I have a Wilwood brake pedal in my car. Although it stops OK, it just doesn't feel right. When I come back from a ride, the rear brakes are warm and the front brakes are cold. Went onto Wilwoods site to find info and discovered that my peddle bias adjustment is WAY wrong. In the instruction/information PDF, it mentions using a brake line pressure gauge to set up the pedal, which I have. Does anybody have any info on starting points for the front -vs- rear pressures or pressure ratios. Or any suggestions on how to set the brakes for proper operation with these Wilwood setups? When do you know it's right?
