Old 05-15-2016, 07:28 AM
patrickt patrickt is offline
Originally Posted by davids2toys View Post
Thanks for the Torques Pat, did you take the aluminum into acct? I am assuming if this were going into a cast iron manifold it would be higher? Same for the aluminum water pump. I have heard of people breaking/ cracking them out from over torquing.
Yes, use the lower end if you're nervous over the torque. I pulled my instructions for the Edelbrock 8805 aluminum water pump and they make no mention of the torque at all. They do remind you to put the little overflow hose on first though.
You know, if it hasn't been drained in 12 years I might just drain it and replace it with fresh coolant again at the end of the summer.
