Old 05-16-2016, 09:22 AM
pormgb pormgb is offline
Banned
Cobra Make, Engine: Rowan Replicars, 352 4V
Originally Posted by strictlypersonl View Post
Unless the front end pivot of the trailing arm is in-line with the lower control arm pivot axis, you need some compliance somewhere. ERA accomplishes that by rubber mounts at the top of the subframe (that contains the rear suspension main assembly).
So the body mounted side of the trailing arm has to be in line with where the LCRs mount to the Axle?
I actually have trailing arms installed, one end has polyurethane bushes and the other has a hiem joint.
[IMG][/IMG]
