Old 05-17-2016, 10:54 PM
damage's Avatar
damage damage is offline
Cobra Make, Engine: Kirkham 427SC 482 Cammer
No you would end up with spark all over the place each output is one reference signal so wont work on sequential firing. It would have been easier if they had designed them with more ignition outputs. Also you cant run wasted spark on CDI system which is what your require for individual coil. You need to run crank sensor for RPM and cam sensor for phasing, the expander then decides timing of spark to each coil.
Something like that anyway ages since I've played with these.
