Thread: Valvolean
  #36 (permalink)
Old 05-18-2016, 03:26 AM
LoBelly's Avatar
LoBelly LoBelly is offline
Originally Posted by Gaz64 View Post
Wow, look at the bend in the valve stem.
Sheared off straight under the valve collets.
Thank god the piston is ok.
Can you see what I mentioned about the lifter for that valve in one of your early photos?
Or is what I see an illusion?
Gary
Hi Gaz
I think it might be an illusion - I just cleaned that lifter to get a good look at it to see if I could find anything wrong
Again, did you find the rest of it somewhere in the engine?
Hi Bernie -
As Gaz says the valve tip just sheared off so the 'rest of it' was retained by the collets in the top of the spring. Its in one of the earlier photos
I should have mentioned this earlier.
Have you thought about going to beehive springs?
The technology is out there now with a lot of spring manufacturers.
Lighter springs, combined with a lighter retainer.
Would also give a little more clearance with the rocker arm.
Gary
That would have been a good idea - but the top-end is back together now and I have issues elsewhere to attend to...
ta
LoBelly
