Old 05-18-2016, 03:38 AM
ICCARS's Avatar
ICCARS ICCARS is offline
Cobra Make, Engine: AC Cobra - ICCARS 001, 4.2LTwin Turbo, AWD, 5 speed tiptronic under construction
Originally Posted by Mrs flatchat View Post
Live axle is good , 4 bar link is good , panhard is Bad --they induce rear steer right when you don't want it , Watts link is good
Back to the topic............
Agreed, the Watts link is the way to go for most modern cars that have a greater suspension travel, however an AC Cobra would only traverse through it's total moment about 25-30mm from full compression to total rebound, hence the pan hard rod is a good compromise for this set up. Trust me, those 16" wide wheels do not scrub and they only have 15mm clearance from the chassis, and 7mm from the body..
It's all in the geometry..
Wil
