Old 05-12-2002, 11:42 AM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
First of all, call EM and see if they have templates they can send you. You shouldn't have to invent this one yourself. If not, than use butcher paper.
On the firewall, foot boxes, and trans tunnel, Summit sells double faced aluminum padding just for this. It's about $40 a roll. You want to put this down first, under the carpet for heat and sound insulation. (And you'll want to ceramic coat your headers and sidepipes too).
Pep Boys sells a single faced aluminum insulation used for insulating vans. It's about $20 a roll. Use this from the dash on back. Put a piece in each door as well. Heavy duty Wiss snips or scissors will cut this stuff, but it's tough, and slow going.
The adhesive, also sold by Trak and Pep Boys is 3M carpet and trim adhesive. Comes in a spray can for about $10 a can. You'll need about a case of this stuff.
Good luck.
