Old 05-22-2016, 08:59 AM
ICCARS's Avatar
ICCARS ICCARS is offline
Cobra Make, Engine: AC Cobra - ICCARS 001, 4.2LTwin Turbo, AWD, 5 speed tiptronic under construction
Default ICCARS - AC Cobra Manufacturers
The Suspension:-
All ICCARS come standard with the Front suspension based on the RX7 Twin Turbo and the Rear suspension being a Nissan Skyline cradle set up with Viscous limited slip diff as standard.
Our suspension set up has been designed to incorporate the best handling possible and the balance and feedback from the Skyline/RX7 combination is sensational, being regarded as the best handling AC Cobras he has ever tested by our certifying engineer here in S.A.
Furthermore, we have incorporated features such as anti-dive, 2x Chassis length Ackermann intersecting angles (similar to F1 style set up) on the steering geometry, zero bump steer and between 9-11 degrees positive castor depending on your application i.e. Road or Race.
What does this all mean - well it means that you will get the sensation of driving a very predictable, precise and well mannered car, that is very safe and friendly to drive.
We also cater for a Live rear axle and 5 link system, should you wish to go that way in order to fit in those bigger tyres that you had in mind..
Wil Escabache
ICCARS AC Cobra 001 (AWD) U/C
RF 098 GT40 Twin Turbo
ICCARS GT40 - U/C
www.iccars.net
