Old 05-23-2016, 10:13 PM
pormgb pormgb is offline
Banned
Cobra Make, Engine: Rowan Replicars, 352 4V
If your wheels use the set screw in the wheel center, here is what I have done.
Take off the spinner and you see where the set screw makes contact, should be in the groove of the spinner. Take a drill and make a small indentation so the set screw can locate in the hole, don't drill through the spinner, just make an indentation.
Tighten up the set screw, then use another on top with some Locktite, you should have enough wheel material to get two set screws in the hole.
This works for me, the second set screw just prevents the first from backing out.
