Thread: Broken Diff
Old 05-24-2016, 06:27 PM
Mark IV Mark IV is offline
Senile Club Cobra Member
Originally Posted by Axel 427 View Post
Yep.....I got the rear end back together. Grey 65 was correct when he said "looks like the 6 bolts holding the half spacer back out." Kinda makes you wonder if these were torqued to begin with.The half shaft apparently hit the wing part of the Diff cover and broke it. I bought a new Diff cover and bolts, and gear oil and re-assembled. The car runs great now, except now I noticed transmission fluid leaking around the rear seal of the transmission. I'm not sure if the previous problem caused this............. Dang!!!!
How hard is this seal to change out ? Anyboby got suggestions?
Vance
Easy to fix. Pull the driveshaft and yank the trans end seal out. Install new seal, reinstall driveshaft and go to it.
rick@autoventureusa.net
