Thread: WOT too Lean
  #43 (permalink)
Old 05-26-2016, 08:23 AM
lippy lippy is offline
If your idle is rich you may also want to look at your idle restrictions. They should be sized so you have the right idle mixture with the 4-corner screws roughly. 1.5-2 turns out. If you need to turn your idle screws all the way in to get the right mixture then your idle restrictions are too big.
If your idle settings are off, it will impact all other settings.
