Old 05-31-2016, 12:28 AM
dan512 dan512 is offline
Originally Posted by Gaz64 View Post
Hi Dan,
I would have your whole fuel system inspected, and possibly redesigned if necessary.
What fuel pump?
How much fuel pressure, do you have a gauge, has the pressure ever been measured?
Does it have a pressure regulator?
Filters pre and post fuel pump?
And as Chris has mentioned above, more than likely a delaminating fuel hose near the carb, that line debris is jamming a needle off it's seat.
Seen this too many times to count.
Gary
It's a Holley fuel pump, no clue what model. Pictures attached.
Pressure regulator is present in the engine bay just before the pressure gauge. Pressure reads around 9psi.
I read in the Holely card manual it should be 6-7,5, so I will dial that down.
Haven't seen a filter yet.
Dan
