Old 05-12-2002, 05:42 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Joe, the assumption, perhaps incorrectly as stated above, is that the alternator is internally regulated. If you have an external regulator, the regulator, not the alternator is most likely at fault, and should be replaced.
I went with a Delco just because of problems like this which is typical of Fords. If you go with a Powermaster Ford replacement, it should be internally regulated.
