Old 06-01-2016, 07:36 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Default EightStack Fuel Injection Ignition Table
Does anyone have an EightStack ignition table they are willing to share?
I have my system up and running and have had the base dyno tune applied. Looking to tweak the ignition table and have some questions.
1) shouldn't the ignition timing be essentially the same as with a carbureted system? The car/motor ran well with carburetors using a 14 initial, 38 total, all in at 3000rpm.
2) looking at my new ignition table, it is "smoothed" so at 100% throttle, at 3000rpm, timing is 33.5 degrees and it doesn't reach 38 till 6000. Shouldn't it be some sort of curve between 1000 and 3000 from initial timing to 38 and then 38 all the way across from there?
My setup is an FE with EightStack and Performance Electronics ECU
Thanks
Paul
www.65shlb.com
www.prdcrrct.com
