06-02-2016, 04:47 AM
KY
Nothing at all wrong with a self-learning system, if that's what it is. I have several engines out there with FAST EZ self-learning EFI systems and they work perfectly.
To answer the OP's questions, I'm not the EFI expert by any means, but your timing curve should stay essentially the same as a carb setup. Total timing at 6000 rpm isn't doing any good at all...
Did you try calling the manufacturer?
