Old 05-12-2002, 08:31 PM
xlr8or's Avatar
xlr8or xlr8or is offline
Easy to check the fuel delivery if you have an electic pump... Just pull the line as close to the intake as you can and put it into a suitable empty container and turn on the key and let it rip. let it run for a couple of minutes... may need to pump out a gallon or two to be sure. I would try that first only be cause you said it took a minute and then fired... May have needed to let fuel pass an obstruction or restriction. Any soft lines in the fuel system? Maybe one got crimped and can't sustain flow..
