05-12-2002, 08:37 PM
FL
Cobra Make, Engine: CMC, Supercharged Ford 5.0 & all the toys.
I assume you have an electronic speedo, but what sender are you using and which Tremec tranny? Did you get a VDO magnetic sender, or using a stock VSS? Give me some detail and I might be able to help out.
I'm using a VDO gauge and needed to retain the VSS in the tranny, and even though it was said by many that the VSS should work, it did not. I ended up building a circuit to convert the VSS sine-wave to a pulsed square-wave that simulates the required VDO sender. Perhaps this is the same problem you're having?
Either way, send some more detail and some symptoms.
-Neil.
www.VEIsystems.com
CMC Cobra, Ford 5.0, EFI, Vortech supercharged, T5Z, 8.8 rear, MII front, 4-wheel discs, A/C, stereo.
