  #91 (permalink)
Old 06-04-2016, 08:39 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by davids2toys View Post
UNREAL Dan, pretty damn clever! Nice.
Would I have to bottom out the stud in the head or loctite it? It would locate the log a little higher. Thickness of the nut and washer, probably about 3/8". Should be enough room left to get a nut to hold it down and in place. Do studs have an Allen head so you can turn them in? Would you happen to know the size and length? Is there a proper procedure for installing studs?
Thanks...Dave
The above is a good idea.
You can get a stud with male or female hex on the end.
Because of it's small drive, I would install them with a "smear" of anti-seize, nipped only, then fit the manifold nuts, torque to 25 lbft, then fit the fuel log, torque to 10-15 lbft.
Gary
