Old 06-05-2016, 04:43 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by davids2toys View Post
UNREAL Dan, pretty damn clever! Nice.
Would I have to bottom out the stud in the head or loctite it? It would locate the log a little higher. Thickness of the nut and washer, probably about 3/8". Should be enough room left to get a nut to hold it down and in place. Do studs have an Allen head so you can turn them in? Would you happen to know the size and length? Is there a proper procedure for installing studs?
Thanks...Dave
Dave -
From what I can find out the center intake bolts are 2-5/8 inch long. If anyone knows any differently please chime in.
So you would probably be looking for 3 inch studs or possibly a 3-1/4 inch stud. ARPs site is hard to navigate for an exact bolt or stud but on Dorman's site I found these that look pretty close.
Dorman Products - 675-006
I found these on the McMaster web site. You can pretty much find any combination of length, fully threaded or partially threaded stud on it.
McMaster-Carr
ARP would be the most likely to have a stud with allen head recess or a screw driver slot in the top. If you have a dremel it would be pretty easy to add a screw driver slot to the top. I would probably install them with some blue thread locker to secure it in the block.
Just based on my motor I can't see how positioning the fuel log slightly higher should create an issue. If the fuel log is hard piped to an OEM type canister filter the line fittings would need to be loosened to re-position it and then re-tightened.
ERA 782 Running
