Old 06-05-2016, 02:25 PM
Luce Luce is offline
Cobra Make, Engine: Lone Star with IRS, 427W with megasquirt, T56 magnum
If you're a HP junky, don't let anyone tell you 350 HP is too much or you'll be back in 6 months asking about fitting a supercharger or turbos or nitrous.
If you're building a slab side, you obviously want a 8.9" block. I would highly recommend a 347 for the extra 45 CI. It's either a free extra 50 HP or a lot more grunt on the low end, however you balance the cam.
I run 315 toyo praxis 17", and wouldn't mind a little more power than my 535 HP EFI 427 winsor has. Passing the toll both, I can slow to 50 MPH, drop it in 3rd and hit is full force and accelerate to 100at full throttle. Then in 6th, purr along at 1800 RPM at 70 or so.
But no, the radio is useless if the motor is running.
Again, with the slab side, you're limited on tires; it cost to play. DON'T SKIMP ON THE RUBBER! It's the most important 80 square inches you have on the car.
