Old 06-05-2016, 03:43 PM
fordracing65's Avatar
fordracing65 fordracing65 is offline
Originally Posted by Joe's Garage View Post
Where's the insult? What I posted was factual, all Brent did paraphrase what I said and then add his own spin as if to "correct".
I guess I need to dumb it down a little. BBs as a family have more low end grunt than SBs. If you disagree speak up. SBs as a family make their power higher up in the RPM range than BBs. If you disagree speak up.
You can build any motor to make power where you want but if you look at the population of both, then what you see is what has been stated - the dyno charts don't lie.
Al G, if you didn't have something to b!tch about you wouldn't have much to say at all. A couple of PMs on that other thread early on gave me a heads-up, they were right.
Wrong again. Like Blykins said. It depends on the cam and heads. He can make a small block with more low end grunt than a big block and he can make a big block with more power up top that revs to the moon. Most of the time it is the opposite like you state. But not always the case. So it's not always the case. I'm not taking sides just stating facts.
PRIDEnJOY
