Old 06-05-2016, 05:52 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Thanks for the comments guys.
The system does run as Alpha-N but also includes MAP Compensation. On the ignition side of things, although it is running using the TPS position as a load indicator, it is very similar to SpeedDensity systems that use MAP to gauge engine load. Although referring to two different sensors, the reference is almost identical.
I agree the table doesn't have enough timing in it, the tuner intentionally set it on the conservative side. I am beginning to tweak that and am still hoping there's an EightStack FE guy out there who will share his table. I know it won't import into my system but it will give me a general idea of the timing curve that he uses
Thanks
Paul
www.65shlb.com
www.prdcrrct.com
