Old 05-12-2002, 09:36 PM
Whaler Whaler is offline
Hi Mike and thanks for the reply to my question.
I am a little confused in that I thought both these wires that we speak of had to come to my ignition switch and end up being terminated there.
So you say I should wire these two together? if so, how does a fuse come into play, is it at the MSD 6AL?
With these 2 wires connected to each other, how do they then see the ignition switch being turned on? I thought the msd relay wire came to the ignition switch seeking switched voltage? Instead you say it will be should be taken from the ignition sw coil wire from painless?
Just so I have this right, I needed to rehash it as I understand you.
these questions may be dumb but its not really obvious to me until it clicks..
I assume you have the painless and msd setup.
Thanks alot
Tim
