Old 06-06-2016, 10:11 AM
ACademic ACademic is offline
The factory uses a thick silicone rubber to adhere them to the back of the dash panel. You will most likely need to use a utility knife and cut a slit on one side, then use some pliers to peel it away. They are in there pretty good but will easily back out once you do this.
